How do I repair a very small oil weep
Break an egg into the oil filler hole then run on full throttle for a few minutes.
That should do the trick.
Alternatively, if its only a small weep, you could tell it a funny story. This might cheer it up a little and it will stop weeping..... Unless it is really depressed. Do you know if it has been abused when it was young.
Only time will tell !!
Just done the repair ( the egg in the engine just made a foogin mess and now my dogs are ill eating it !!)....used that steel epoxy putty....see the pic attached ( I should have been a gynaecologist the way I got in and up there:augie )...looks good...just got to put fresh engine oil back in and thrash the goolies off her :)
Only time will tell..........
...probably 30 seconds around the block !!
