how do you hear yours ?
(RIP) Kaister
not near to you
I'm about to fix my sp3 onto the bike - still haven't decided a few things yet.
Ram mount from the bars or bmw / garmin mount to h'bar cross bar.
Ideal position would be above the clocks on a quick release.
I've seen the 1150 clock surround mtg plate, but i've got an 1100.
Next dilemna is how to hear it.
speakers into helmet - but how do you connect it up every time ?
helmet jack plug connected to flying lead from where ?
jacket ? bike ?
so where does the lead go if you don't use it ? it'll need storing somewhere - or qd from bike?
earpiece ? fiddly to put in and also the lead problem.
speaker ? needs to be waterproof but would it work at speed ?
bluetooth is ideal but flakey at the moment.
needs to be very quick and easy to connect / disconnect and no wires about the place getting in the way.
Also the sp3 needs to be quickly and easily removable for car use.
I can't figure out the ideal way for all of these options - how do you do yours ?
I've got a pair of very thin speakers, from Rainbow ~£25, that fit easily into my helmet. This leaves a short jack socket sticking out of the helmet that you plug a (supplied) lead between helmet and SPIII. Dead simple, quick and easy (dis)connect.........
Store the lead in a small bar bag - Hein Gericke thingy.
Regards
Tim
Into an Autocom together with the Ipod, Phone and Radio......
I use MiGSel's Bracket for the unit...:thumb and have the Wires (Power and Sound) run behind the dash, under the Tank to the Battery/ Tank Bag ( Where I have the rest of the above)..........
Apart from a glitch still to be resolved plugging the Ipod and GPS into a 'Special' Autocom Lead,........it all hangs together well.
But I guess you're not looking for the rest of the Kit..............?
CC
:cool:
Mine is...
a touratech mount on the handble bar cross strut. Purchased a garmin car power/audio connector, cut of the speaker/cigeratte plug, routed it from the handle bars under fuel tank, wired a 3.5mm audio socket to it, power lead to battery thru a fuse and a set of earphones. Works ok for me.
Mick
and other end
this socket when not in use tucks under seat...and an adapter that converts mono to stereo so you hear it in both ears
Mick
