tosh23
Im in the middle of stripping the GS and I thought this might be useful to someone...
How to get these little round caps off...
Ive read another thread on here somewhere but without pictures so...
As you look at the rear end of the bike...
Just above the exhausts you will see a little yellow line that's where you go in,
Just look closely and you will see this...
Look closely and you will see the little notch that you need to put your small flat
bladed screwdriver into, Get the screwdriver in there and push slightly
and twist anti-clockwise.
Then it should pop out of one side the the disc.
There is two tabs on the disc, so just get a small screwdriver and gently prise
the other side out being careful not to damage the plastic...
I hope this helps someone, Remember be patient, very patient and good luck...Tosh..
