How to make the LC more pillion-friendly.
Possibly, I've made the problem seem much worse than it actually is.
The grabbiness of which I speak seems to manifest if I pull away from standstill on a very light throttle with revs below 2 000 (my hexheads did this perfectly). If I hold the revs at or above 3 000, still on a light throttle, the grabbiness is greatly diminished.
It's not like the clutch has a 'switch' action in the same manner as a racing clutch. It's just not as progressive as the clutch action I had on my hexheads.
Put it this way, I would choose this clutch over the Sachs button clutch I had in my first GS Adventure any day.
One thing I did check last night was the fluid levels.
Thinking the clutch reservoir might be overfull, I undid the lid. Sure enough, fluid came pouring out. Even with the lid off, the fluid level was over the brim of the open reservoir. I removed a little over 6 millilitres with a syringe before closing the lid.
The front brake reservoir was also overfull.
It seems the dealer did a half-arsed PDI on this bike... surprise, surprise.:blast
You are not the first to say that the clutch and brake reservoirs were over filled to the point where fluid came out when the cover was removed - one wonders how the dealer put in more fluid than the reservoir can hold? - I am confused as to how they do it?
