HP_Mic
HP2 Enduro is out of BMW site, so here are the specs if anyone wants to have a look.
Engine
Number of cylinders. . . . . . . . . . . 2
Valves per cylinder. . . . . . . . . . . . 4
Type . . . . . . . . . . . . . . . . . . . . . . . Flat twin
Capacity. . . . . . . . . . . . . . . . . . . . 1,130 cc
Bore / stroke. . . . . . . . . . . . . . . . . 101 / 73 mm
Output . . . . . . . . . . . . . . . . . . . . . 77 kW / 105 bhp at 7,000 rpm
Torque . . . . . . . . . . . . . . . . . . . . . 115 Nm at 5,500 rpm
Compression ratio . . . . . . . . . . . . 11.0:1
Valve / gas control . . . . . . . . . . . . HC (high camshaft)
Carburetion . . . . . . . . . . . . . . . . . BMS-K
Chassis
Frame type. . . . . . . . . . . . . . . . . . Tubular steel trellis frame
Front wheel location . . . . . . . . . . WAD UPSD fork Ø 45 mm
Rear wheel location . . . . . . . . . . . BMW Paralever
Travel front / rear . . . . . . . . . . . . . 270 / 250 mm
Caster. . . . . . . . . . . . . . . . . . . . . . 127 mm in normal position
Wheelbase . . . . . . . . . . . . . . . . . . 1,610 mm in normal position
Steering head angle. . . . . . . . . . . 60.5° in normal position
Brakes, front. . . . . . . . . . . . . . . . . Single disc Ø 305 mm
Brakes, rear . . . . . . . . . . . . . . . . . Single disc Ø 265 mm
Wheels . . . . . . . . . . . . . . . . . . . . . Cross-spoke wheels
Front. . . . . . . . . . . . . . . . . . . . . . . 1.85 x 21
Rear . . . . . . . . . . . . . . . . . . . . . . . 2.5 x 17
Tyre, front. . . . . . . . . . . . . . . . . . . 90/90-21 M/C 54 Q M+S TL,
MCE Karoo (T)
Tyre, rear . . . . . . . . . . . . . . . . . . . 140/80 – 17 M/C 69Q M+S TL,
MCE Karoo (T)
Electrical system
Generator . . . . . . . . . . . . . . . . . . . 600 W
Battery . . . . . . . . . . . . . . . . . . . . . 12 V / 12 Ah maintenance-free
Headlamp. . . . . . . . . . . . . . . . . . . H4 W
Power transmission/gearbox
Clutch. . . . . . . . . . . . . . . . . . . . . . Single disc dry clutch Ø 180 mm
Gearbox . . . . . . . . . . . . . . . . . . . . Constant mesh 6-speed transmission
Gear ratio . . . . . . . . . . . . . . . . . . . 2.82
Dimensions and weights
Length, overall . . . . . . . . . . . . . . . 2,350 mm
Width, overall with mirrors. . . . . . 880 mm
Handlebar width without mirrors . 828 mm
Seat height. . . . . . . . . . . . . . . . . . 920 mm
Empty weight (DIN standard)*. . . 195 kg
Dry weight . . . . . . . . . . . . . . . . . . 175 kg
Permitted total weight . . . . . . . . . 380 kg
Fuel tank volume . . . . . . . . . . . . . 13 l
Performance data
Fuel consumption
90 km/h . . . . . . . . . . . . . . . . . . . . 4.1 l / 100 km
120 km/h . . . . . . . . . . . . . . . . . . . 5.5 l / 100 km
Acceleration 0 - 100 km/h . . . . . . 3.2 s
Top speed. . . . . . . . . . . . . . . . . . . 200 km/h
Colour. . . . . . . . . . . . . . . . Indigo blue metallized / alaska grey
Engine
Chassis
MCE Karoo (T)
MCE Karoo (T)
Electrical system
Performance data
Fuel consumption
