End Result
Just in case someone else is in the same lane, here is what I had to do to get it all sorted:
Need docs from Customs to prove that the vehicle is not subject to import tax and customs duty (I have owned the bike for more than 6 months, so ok) They wanted proof like Insurance receipts, Reg docs from the country where it was regstered etc.
Also need a European Certificate of Conformity which you can get from BMW UK, Homolgation Dept.
The ECC lists 50+ points which include the information you need to fill out the forms required by VOSA in order to make an appointment to have the bike inspected by them (and they do inspect it!)
You are allowed to ride to and from the inspection station on the day of the inspection however to do that you need insurance and until you get the plate number etc. the insurance company will only insure you for 21 days using your frame number.
After you pass inspection you have to take all your docs to DVLA and they will then issue (by post 5-10 working days) your final plate number/V5 docs etc and then you can legally join the fray.
The docs DVLA requires are:
personal identification like passport and bank statement or utility bill showing your address, reg docs from the imported country, Customs clearance, the VOSA inspection certificate, the ECC and a UK Certificate of Insurance.
Points worth noting are:
If your ECC says that the speed indication is Metric you may need to either replace the speedo, instal a second instrument like a Trailtech unit or (only a suggestion) paint over the "k" in the "km" label on the speedo face plate coz nobody checks the speed indication! they only check the lettering on the face.
I had to buy a new headlight glass 165 quid, ECC 56 quid, inspection 85 quid, plates 10 quid and insurance 400 plus.
I needed about 14 days to get it all done but the insurance company was on the case and warned me after about 15 days that they would cancel my policy and I would have to start again if I went over 21 days.
The guys at VOSA were good, they checked everything, a very hefty MOT!
