JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
HiD50.com leading light in HiD
Has anyone any view's on the Hugger, I've seen the comments on the earlier thread's and it looks like the Pyramid ones have been improved, but are they worth it?
Les
Get one !!
Les,
It certainly helps keep the crap off the Shock.
I had a Pyramid but found that as I rode two up most of the time, it kept clouting the undertray.
I ended up with one from
www.gs-fun-factory.de which is closer to the tyre and onlt touches occasionally on full compression.
Checkout my bike at
www.coolcarbon.net , It fits via the rear brake pipe locating loop and the bottom shock mounting bolt.
CC
