Hydraulic chlutch hose?
t'other dave
warrington
I have just checked my 2000 1150gs ready for 2500 mile alps trip in 2 weeks and found that the hydraulic hose has rusted away at the slave cylinder, cut back the rubber and tapped off the rust, I can only see thread, I take it that it should look like the master cylinder end and have a sleeve/nut to connect the flexi to the metal banjo.
http://www.ukgser.com/forums/showthread.php?t=59976&highlight=clutch
So is it a dealer part? Or does anybody stock a goodrich replacement (as in steptoes thread) and what what kinda price is it?
Also the bleed nipple for the cluch is seized does this require a new pipe or is the bleed nipple replacable?
Thanks in advance Dave.
motorworks had a s/hand one for £16 posted that i fitted to colts bike as for the main hose i can make you up a cable at £9 trade :comfort
but yes the bleed nipples do rott soild :blast
you can strip the hose out by taking rear shock out then turn it to the left
