I can't see!!
The Slow Granger
West Sussex, England
Tobinators - great for stopping the buffeting but rain clearance from the visor now seems impaired.
The water droplets are smaller and less wind prevents the water from beading and being cleared by the old air wash that caused the tobers to be put on in the first place! :confused:
Can anyone tell me if the tobinators are set incorrectly (although I have tried different angles etc.) or a better way of getting rid of water from the visor. :nenau
Steve
Hi Steve,
Try lowering the screen a bit by lowering both the front and rear risers by the same amount. I'm assuming you have the front risers set high. Keep the angle of the screen the same.
This should bring the airflow down a tadge and hopefully onto your visor, whilst maintaining the smoothness.
Alternatively, utilise left index finger as a visor wipe :D
Andy
Polish your visor with car polish or wax, it helps! Causes the water to form into droplets and roll straight off!
Stand up on the pegs every now and then,get a good blast of air on the visor.That'll do it. :clap
wiper speed?
thanks - all will be applied and I'll try then the index finger trick. How do I get intermittant and speed control of the wipe setting? :D
