themadprofessor
Grumpy old B*st*rd
Help,
R1100 RT '98 started today after a three day lay up and after about a mile it cut out. I coasted to halt. Typical Hall effect sensor symptoms - Dancing Rev counter and fuel pump running briefly and then stopping.
Tonight I have stripped the buggar down and tested the HE sensor. Trouble is that it seems fine and works as expected. The only possible problem I could see was corrosion on the pins of the connector. One final piece of diagnostic. I had to push the bike about a mile along a busy road to get it home so I had the ignition on with the hazards going..... that is until the relays started going bananas. I decided I did not like this and turned the ignition off. Battery is one year old but OEM type and I do occasionally get the alternating ABS light syndrome on cold mornings.
Tomorrow I shall reconnect the HE sensor. Has any one any other suggestions on what to check before I reassemble the machine.
Thanks Chris
Thanks Chris
