Indicator Help
Doc
English and Proud
Slawit
Before I waste anymore money could anyone tell me if these are the correct inserts I need please.
Also if these pannier bag lights are any good to anyone you can have them. Both work run red & turn red. Can't remember if they have break lights aswell.
If the turn signal housing in the picture is from your bike, then those inserts should work. The housing has the two pins in it, which means it's an 1157 type rather than the single pin 1156.
This means that you will have power to the headlight housing for both the turn signal and the "halo".
BUT - check that you have three wires going into the turn signal housing. It's difficult to tell from the photo, I can clearly see two wires - but is that a third kind of hiding behind? If so, you should be good.
Great thanks. Definitely 3. Turn signal housings are for my passing lights.
