Indicator problem, fixed
rc mad
scunthorpe, north lincs
Just an fyi really, my right hand indicator has recently started to play up, not switching on when the indicator is on. :blast
Took the switch assembly apart today to find the contacts corroded, cleaned them up and stuck a bit of dielectric grease on them, problem sorted :thumb2
I'm atributing the corrosion to the ammount of time the bike spends out in the wet, its outside all day at work and i've done a couple of rides where its been pissing down, always seems to be in scotland that, mostly glasgow but edinburgh is not far behind :D
It is a good habit to spray all connectors with wd40 every so often to prevent corrosion.
