Injector Cleaning
Stephen
Yes, I've been there as well. A problem with the injectors and a shelf load of injector cleaning products that promise the earth.
I work in Jaguar Cars R&D on Electronic Systems.
I had a chat with Joe in work - he is the chief injector bloke. I had a problem with my old 2.8i Granada.
His wisdom is summed up here:-
Basically, if you are having problems with your injectors, then it may well have got too bad to do anything about it, and replacement is the sure-fire fix for duff injectors.
But it may be possible to recover the injectors by Ultrasonic cleaning. This can be done buy many specialists.
Regarding products that clean up your current injectors, they comissioned a test of all the products available, including their own, and the best turned out to be good old Redex.
Used a little and often is best.
He swears by it, and I have to be honest, I have never had any recurring problems with injectors or carbs since then.
I put in about 1/2 the recommended dose every 3rd tank or so.
But he also warned, that injectors (all injectors) are generally very reliable, and need little or no maintenance other than regularly changing the fuel filter, so if you think you have problems that may be injectors, it might not be.
A few little tips from him:-
Always use good quality fuel - steer clear of supermarket fuel.
(I use Shell Optimax, and there really is a difference - smoother, easier starting, less pre-ignition)
Use Redex a little and often.
If you are removing injectors, don't lever against the injector body, as although the outside damage on the injector looks nothing, it may well jam up the insides. Gently ease the injector out, using oil to ease the o-ring if it's dry.
If installing injectors NEVER NEVER use silicon grease (although some "Experts" and haynes manuals say this is the stuff to use.
Silicon grease does not dissolve in petrol, and can land you with more trouble than it's worth.) Use standard engine oil on injector O-Rings.
Change the fuel filter regularly.
Are you experiencing any particular problems? or was your question a general one?
Cheers,
Mike.
