Installing a DVD drive
BigNige
Essex innit
Somewhat dimly I didn't specify a DVD drive on this new Dell pc and am wondering, if I buy a drive, how easy they are to install?
Also, which drive might be best so that I can chop & change between various regions of DVD?
Cheers mates
installing advd
should be no problem..
but it depends on how pc friendly u are..
have you ever taken apart a pc?
do you know what the inside look like and roughly what they do?
any good with a screwdriver?
if you can say yes to these then it should be no problem..
have a look at www.scan.co.uk for prices and parts
eg LG DVD ROM Drives £32.31 sterling plus delivery..
there are better ones as well..
anyway you plugs in the unit.. 2 leads, one for power and one cionnects to the motherboard..
you install teh drivers.. they should be on disk cause the cd wont work untill u install them.. catch 22.. or else you can have normal cd player and dvd player as well, if your pc has spare slot to put in unit.. if its a dell it should be ok..
i have a dell witha dvd player and a cd writer and it ahs the correct cables in side.. so u should be ok, anyway its no problem getting extras if you need them..
hope this helps..
oh as for region 1 2 3 4 etc players..
there is different softeware out there to do this..
again depends on the unit u have.. i will check out some sites and get back to you
email me at [email protected] if you have any questions
regards
pthagonal aka Ian
