Alv8l
I'm trying to remove the intake tubes on a GS1100. These suckers are in tight. I can twist them slightly when I loosen the clamps. Do you usually have to pry off the rubber seals to get them out? Or do they slide into the airbox? Just wondering how much force to use or if I need to get a bigger knockometer?
Any tricks you may suggest are appreciated.
Any tricks you may suggest are appreciated.Thanks
