internet options
Wolfman
Widnes
Home page, it will not hold to UKGSER.com, it says it does, ie apply and ok. But then reverts to
"res://shdocnvt.dll/blank.html"
any ideas ?
By the way my son uses this computer, so I know he goes on sites he shouldn't you know what I mean. :eek: :eek: :eek: :D :D :D
Gary
Gary- You've been hijacked.
You might need to get 'Hijack this', a prog designed to identify and produce log files of this sort of problem.
Here ya go step by step;
Step 1
We need to disable your Microsoft AntiSpyware Real-time Protection as it may interfere with the fixes that we need to make.
* Open Microsoft AntiSpyware.
* Click on Options, Settings.
* In the left pane, click on Real-time Protection.
* Under Startup Options uncheck Enable the Microsoft AntiSpyware Security Agents on startup (recommended).
* Under Real-time spyware threat protection uncheck Enable real-time spyware threat protection (recommended).
* After you uncheck these, click on the Save button and close Microsoft AntiSpyware.
* Right click on the Microsoft AntiSpyware icon on the taskbar and select Shutdown Microsoft AntiSpyware.
After the computer is clean, it is very important that you enable Real-time Protection again.
Step 2
Open HijackThis, run a scan, then check the following:
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = res://shdocnvt.dll/blank.html
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
O4 - HKLM\..\Run: [Fast Home] C:\WINDOWS\system32\svcnvt.exe home
O9 - Extra button: Related - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O9 - Extra 'Tools' menuitem: Show &Related Links - {c95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\WINDOWS\web\related.htm
O21 - SSODL: SysTray.Exgr - {5368D1FC-4F5C-4f1b-B134-E67214FC78E9} - C:\WINDOWS\System32\iflelqeg.dll (file missing)
Fix these if you or an administrator did not set these restrictions with Internet Explorer or a program such as Spybot S&D wasn't used to set them.
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Control Panel present
With all other programs and browsers closed, click fix checked.
Step 3
Please set your computer to show all files.
* Double-click My Computer.
* Click the Tools menu, and then click Folder Options.
* Click the View tab.
* Clear "Hide file extensions for known file types."
* Under the "Hidden files" folder, select "Show hidden files and folders."
* Clear "Hide protected operating system files."
* Click Apply, and then click OK.
You will need to reverse this process when all steps are done.
Step 4
Please delete the following files:
If you have any problem deleting these items, reboot into Safe Mode (tap F8 during bootup, use arrow keys to select Safe Mode, then hit 'enter') and try again.
Step 5
Reboot normally and scan with HijackThis
Cheers mate
Thanks for the info, will try this in the morning,
best regards
Gary
