Timbuktu
Hello Each,
I'm after a bit of help and advice please.........
Riding my 1996 1100 (only has 110k on the clock – so just run in then) over the past few days I've noticed that accelerating in 5th tends to cause the revs to rise, but a momentary lag between the rise in revs and the bike gaining speed. It tends to be between 3500rpm and 4500rpm/60+ mph there or there about.
I can't say that I've noticed it when pulling away from lights and going through the gears, but it is noticeable in 5th but not all of the time. to further confuse the issue, the bike maintains it speed and stills pulls like a train, the "top end" seems unaffected, whilst on the flat and when on long hills - so far
I've spent the last couple of days trawling through the boards of this site trying to gain some insight as to what it may be; so far as I can ascertain, it sounds like it could be clutch slip, but then again it could be "surging" (not sure I'm any clearer as to what surging is having read about it!!!)
I appreciate that diagnosis over the net is difficult, but in the experience of folks that frequent this fine site, any suggestions on what it could be - or is it Clutch slip?
If so, can anyone recommend a place to get it fixed in and around the Wilts/Somerset/Dorset area.
Your help and polite suggestions are welcomed,
Regards,
Timbuktu
Regards,
Timbuktu
