I can't see the picture but I'm guessing its the discoluring of the top of the cylinder head with the rocker cover off? I had it on mine, I wasn't burning any oil but as I didn't know how old the valves were and I was bored I changed the vales and the guides at the same time. Once the springs were off I found that I did have a bit of play but nothing too scary. Changed the guides at home (not so hard) replaced the valves and everythings fine. I have no discolouring at all now so summat was slightly worn I guess. The local "Experts" wanted to charge a fortune to do the work hence the reason I did it chez Sylvester. Plus I took my time and cleaned everything up at the same time. Depending on how mechanically squeemish you are, it wasn't too hard to do but stunk the house out as I had the heads in the oven to get them hot to drive out the old guides.
