Hi everybody I hope somebody can help, because I slowly become crazy.
I have a R 1200 GS (2008) and my big desire to connect to him. I have only one hurt. It can’t.
I tried approx. every combination of cables and software. I don’t know what I doing wrong. What I checked first, that the cables. I have a K+D can cable not from AliExpress or something, but I think basically it come from china (like everything). I have 10 pin round shaped – OBD2 cable too (china).
I measured the pinouts and the result is the same what I found everywhere.
brown/black (motorbike connector wire) – 7 (OBD2) – 1 (10 pin adapter) – K line 1 BMS
brown – 4,5 (OBD2) – 4 (10 pin) – Ground
red – 16 (OBD2) – 6 (10 pin) – KL30 Batt
green/blue – 1 (OBD2) – KL 15 (ignition ON)
Interesting (for me): in my motorbike connector the pin 8 is missing (K line-2 ABS) and the Can HI & Can Low too.
When the ignition on, I measure +12V on OBD2 connector’s pin 1 and 16. So I think this is OK too. By the way in ISTA+ I don’t see voltage on KL15 and KL30.
I tried to reprogram the K+DCAN cable’s FT232RL chip. I inverted the RI # and DSR# signals.
Of course, I made tries with normal state of cable too.
Softwares:
INPA: my version just for cars, but it seen my cable and the ignition is ON, but when I switched off the ignition nothing changes
ISTA+ (I tried different wersions, like below):
- Win 7 x86 with ISTA+ Béla with Mike’s BMW standard tools
- Win 7 x86 with ISTA+ 4.10 with Mike’s BMW standard tools
- Win 10 x64 with ISTA+ 4.26.22 Sedoy Standalon + Jok3r5 BMW standard tools + patch
- Win 10 x64 with ISTA+ 4.10 with Mike’s BMW standard tools
I always use the FTD chip cable official driver. I set the port latency to 1 and changed Ediabas\bin folder’s OBD.ini (com port) and ediabas.ini (STD:OBD, TCP port 6801).
I every time check different versions like:
- COM9, COM1
- cable switch to K and D too (I think the K is what I need)
There is someone on earth who has succeeded connect to BMW Hexhead with ISTA via K+DCAN cable?
I read out the complete internet but I run out from ideas. Please help, I hope this is not an impossible mission.
Softwares:
- COM9, COM1
