It looks like the 2610 mount is the same as a Zumo
BigAlMacMac
North Glasgow
if so then my exisiting Motorrad concepts mount for my 2610 will also work for the Zumo. True?
Though the Zumo looks like a much taller unit so might touch the screen.
Anyone with that experience?
StreetPilot 26xx, 27xx and 28xx series cradle (they all use the same one) is totally different to the Zumo one I'm afraid.
EDIT: Whoops... Sorry, thought you were talking about the fit of the unit. :blast :blush
The SP3 / 26xx / 28xx GPS mounts from Garmin use the same basic layout for the 4 holes that you can use to bolt the mount to a RAM mount for example. So I'd guess that the Zumo will probably have the same hole layout, and space permitting, it'll bolt onto a mount that was suitable for a 2610.
Thought about using a spacer (or washers) and longer bolts to push the Zumo away from the mount / screen to give more chance of it not fouling the screen?
The concepts mount will work with the Zumo although as the unit sits lower in the mount you may "lose" the top of the rev counter. I found by unbolting the top of the mount and turning it 180 degrees it cures this although affects screen adjustment a little.
Stumpy
