Khyam Atrium Canopy and Shader Tarp
st247
North East Riviera
For those of you looking for a bit more flexibility with your Khyam or other tents, how about this-
The blurb-
Khyam Atrium Canopy
This is one of the best ideas for the 2008 season - the Atrium is essentially a sun canopy for small tents which will create a great sheltered dining/cooking/sitting area on those balmy summer evenings (Barmy in Stan's case). The Atrium is designed to fit onto the front pole of any tunnel tent or dome tent (with a porch pole). The height of the Atrium can be adjusted to suit but the ballpark height for a good fit is 1.3-1.5m. The construction is 9.5mm Fibreglass poles with 185T Polyester flysheet (5000mm HH).
Pack Size: 64x12x12cm
Weight: 3.9kg
RRP: £50
Nuts!
Megastore Price: £39.99 (€58.30)
Found here.
There's also this one-
The Blurb -
Khyam Shader
A shader or tarp (Stan's got a pond full) which provides temporary shade or shelter. The construction is steel poles with a 185T Polyester flysheet (5000mm HH).
Size: 200cm Max. Height
Pack Size: 55x13x13cm
Weight: 4.3kg
RRP: £70
Golden!
Megastore Price: £54.99 (€80.17)
From the same place.
