Knock sensor values
johnpatsa
Greece
After changing coils plugs and tps my bile starts running like normal...just a last issue..why the Knock sensor saws different values cylinder 1&2?maybe synchronization? also nthe lambda 1&2 has a little different values
Στάλθηκε από το JSN-L21 μου χρησιμοποιώντας Tapatalk
It is important that knock sensors are fitted correctly. The securing bolt has to be tightened to the correct torque. Overtightening a knock sensor bolt will scrap the sensor.
I think they are a piezoelectric sensor and very sensitive.
So, was it the secondary coils causing the rough running?
I think all the 4 of them...at 85000km...after change much smoother running
Thanks John, I think mine maybe the same, 153,000 miles and what looks like the originals......
Did my secondaries not so long ago (Beru), gonna order a pair of primaries soon. My secondaries improved running so hopefully new primaries will also help, mine sometimes has a wee stumble and a spate of rough running.
Also give as the spark advance angle...mine is 12º
