I have a leak that started overnight from the rear wheel. At first I thought that I had a pucture but on close inspection I could find nothing. As I was in a hurry, I inflated the tyre and kept my eye on the tyre pressure monitor display. During the journey it lost no pressure, but when I came back to the bike a few hours later it had lost pressure. I had a new trye fitted (it was due one) but the problem persists. I traced it to where the valve comes through the wheel and also found the nut was loose. After tightening this up, the leak seems less. My question on this is, are there seals on the TPM unit/ valve that can fail and cause this? If so, it's probably a warranty issue (2012 GSA)
TIA
TIA
