Mine just arrived in the post.
"As you'll know, changing the Low Beam bulb is a fiddly fucker, as you have to do it my feel alone. So fitting the LED and Ballast was quite tricky, but it all went in, and only took me about 15 mins."
WHAT??!!
"Install pics not possible, as I did it blind and by feel only. Accessing the low beam is a PITA unless you strip the front end"
How in Goodness name did you do it in 15 mins?? --unless you had a 10 year old double jointed boy handy...
I've just managed to connect the bulb to see how bright it is. Left arm coming up from below, right arm holding the OEM connector from above.
LED doesn't come on with the ignition on as the OEM does, but lights up with the engine running.
15 mins.... does that include the time taken to remove the front suspension completely???
I'll try again later and let you know how I get on....
I did say its a very fiddly job. The reason i can do it in 15mins is because i've been doing a lot of playing around at trying different bulbs, so i'm well practiced.
So, have you fitted it yet then?
