chipsonfriday
Fitted a light bar to my GS a while ago and thought I would share a piece of advice.
MAKE SURE YOU FIT IT PROPERLY.
I bought the Migsel light bar second hand from here and fitted it after getting the correct fitting kit for the year (2006) from Migsel. Everything looked good and a test at night showed the lights were effective.
It was the following day that I noticed the scratches on the top forks. I hadn't mounted the bar far enough forward.
Now fixed but stuck with those ugly marks.
I must stress it is NOT the fault of the supplier or a design fault, it was purely my mistake. So be warned - make sure the forks are clear of the light bar at all angles.
Chips
Chips
