Wino
Hi all, Just purchased a 1100 gs with 20000 miles on the clock. was happy with the bike until I found that what was said to have been done was not .Full service ? when I descovered that there was no brake fluid in the rear master resevoir and the tail light was not working. Which brings me on to asking the question, when removing the lense found that the bulb was okay. Run a meter on the connections and had 12 volts but upon putting everthing back with a new bulb, it stopped working again. So off with the reflector again and then found no voltage. So I played with the fuses and found that it was working again. All of the connections seem to be clean and I was wondering if this is a common problem or not?
