LINKS still invisible
Deleted account 231205001
Did anyone ever find out what happened to the LINKS buttons at the top of the page, I still can't see mine ?. NTL broadband
Ok on mine
BL ~I use ntlworld b/band and can see them fine, this topic has been covered before but I din't take much notice of the problem cos it didn't bother me, might be worth doing a search to see if you can find the thread and answer to the problem. IMHO I think it is probably in your IE security settings.
OK for me on ntl Broadband.
Are you by any chance running ZoneAlarm with pop-up blocking enabled? That used to make some of the buttons "disappear" when I used it.
The link buttons were written using Java script so, as long as you have nothing blocking this type of coding they should appear :confused:
A HAH !!!!!!!!!!!!!!!!!! Should have read the previous link about this again ( Thanks Fanum, I think it was your entry )
I enabled Java stuff in internet options. Then I deleted temp internet files and as if by magic, they appeared !.
Be gentle with me, I'm gradually getting a grip of the computer.
Cheers and thanks for your help
