mike reakes Guest Jan 12, 2004 #1 I know this has been discussed before but can anyone tell me how much the different ones are and where you can get them? Thanks
Ned Flanders Guest Jan 12, 2004 #2 This is what occasionally happens when you have the Wunderlich version, but only takes a few minutes to "fix". Regards Tim Attachments oilfiller.jpg 92.6 KB · Views: 316
Ned Flanders Guest Jan 12, 2004 #3 ooooopssss Should have added Wunderlich locking filler cap £17 ?? from the Wunderlich website. Uses a 7mm ? allen key (supplied) to lock/unlock. Regards Tim
woodsie Well-known member UKGSer Subscriber Joined Apr 20, 2002 Messages 955 Reaction score 0 Location Maidstone, Kent Jan 13, 2004 #4 I've got the Wunderlich one And I've pulled the seating out with the plug. If you push down as you turn the plug the seating does not come adrift. It works for me!
Ned Flanders Guest Jan 13, 2004 #5 Re: I've got the Wunderlich one woodsie said: And I've pulled the seating out with the plug. If you push down as you turn the plug the seating does not come adrift. It works for me! Click to expand... Woodsie, I'll try pushing down a little harder next time Regards Tim
yellowwolf blah blah UKGSer Subscriber Joined Jul 28, 2003 Messages 207 Reaction score 0 Location watford herts Jan 13, 2004 #6 Re: Re: I've got the Wunderlich one Ned Flanders said: Woodsie, I'll try pushing down a little harder next time Regards Tim Click to expand... no ned diddly no you'll get piles if you strain to hard
Ned Flanders Guest Jan 14, 2004 #7 Re: Re: Re: I've got the Wunderlich one yellowwolf said: no ned diddly no you'll get piles if you strain to hard Click to expand... Piles of what Regards Tim
