Sold Lone Rider BMW R1300GS MotoRacks – Motorcycle Luggage Pannier Racks
68dicky
Member
Dalgety Bay, Fife
The Lone Rider MotoRacks
– Crafted with meticulous care, these racks are built to withstand the rigors of your journeys.
— Key Features1. Seamless Integration.The MotoBags are pre-setup to seamlessly connect to Lone Rider Racks using a plug-and-play system. Enjoy a hassle-free setup that ensures a secure attachment, letting you focus on the ride ahead.
2. Stainless Steel Build.Engineered from high-quality stainless steel, these racks offer long-lasting resistance to corrosion and rust. Your motorcycle deserves gear that stands up to the elements, and these racks deliver.
3. 18mm Tube Diameter.With a sturdy 18mm tube diameter, the MotoRacks will flawlessly handle the weight and stress they get exposed for.
4. Built to Last.Adventure-ready with a robust design, these pannier racks are crafted to endure the challenges of various terrains. From off-road excursions to long highway rides, they're designed to keep up with your journey.
5. Easy Fitment.Engineered for a perfect fit, these racks seamlessly integrate with your motorcycle. Each pannier rack is checked on precision jigs for a specific tolerance. No compromises on aesthetics or functionality.
— Product SpecificationsStainless steel electropolished 18mm tubeStainless steel hardware— What's included?1x Left-side flat Frame1x Right-side offset Frame1x Support bar2x Passenger Footpeg Adapter bracketsMounting hardware
Item unused and had a slight fault with rivet bar - now professionally repaired. Note these items are unused and are being sold as New (Other). Note one screw length is slightly shorter for attaching the rack connector - not an issue in use.
These racks can take LR bags/Touratech boxes (please check) and BMW aluminium boxes (please check).Any questions please ask.
£250 new.
https://www.ebay.co.uk/itm/25694963...H22G74&hash=item3bd3644d2e:g:2M0AAOSwYv9oNiyL
