Radman
This is in regards to my R1150RT 2002
I'm looking for anyone that has had this problem or similiar. My dealer is clueless, and has no idea what is wrong. In fact, they can't even identify the symptoms. They know of no other report similiar to mine. I need information because the dealer can't fix it, and I'm not very confident about these brakes.
I noticed this problem a couple months ago. Didn't think much of it, in fact I thought it was me. Some of you are aware how sensitive '02RT brakes are at slow speeds, and I thought I was just not finessing the brakes properly.
I finally caught on to what was happening. The brakes release, momentarily, at speeds 20-25mph or less, while I am braking moderate to lightly.
Example: Your approaching a stop sign applying light braking for the traffic ahead. Suddenly, without warning, the bike lurches forward as the brakes release, and just as quickly the brakes are back on.
This is not bumps or gravel. I verified it by running in gear and applying light to moderate braking, and maintaining 15 -20 mph. The bike would lurch every time the brakes kicked off/on. It never stays off, just off/on, about as fast as your reading this. This symptom does not occur at every stop, but is intermittent. It doesn't seem to do it at higher speeds, but it did do it once at about 40mph. It occurs on clean, dry, flat pavement.
My dealer replaced the brake ABS module/pump about three weeks ago. The problem seemed fixed, but resurfaced. I'm told there is nothing they can do. Bike is under warranty.
I'm looking for ANYONE that has had a similiar problem.
Maybe I should have said hello first.
Thanx, Rick
Thanx, Rick
