Fritz,
This is a standard bike IE: Not lowered.
I'm guessing that Bev has an inside leg measurement of about 29" ??
My partner Jill, is 5'3" with a 29" in-seem, a Friend is 5'1" also with a 29" in-seem. Both have standard 650GSs with the forks slid up through the yokes by 20mm. Both can reach the ground with the balls of their feet.
If Bev is shorter in the in-seem than this she will probably be better off with lowering links fitted (you need to look under the bike just in front of the rear wheel. They look a little like Dog bones and are attached to the bottom of the rear shock and the swing arm) get on your knees and have a look. You will need the 1" links, as well as dropping the forks as above.
If you need any help/advice drop me a PM.
Val.
BTW where's the bloody beak???????
PS: You could get them to knock off £200.00 for that
PPS: Catch up Val
Just looked at the photies. If your considering it. Drive a hard bargain IE No more than half the probable retail value from a private seller. If you need to change the fork stanchions, you will probably need to change the lower yoke too. You might as well do the head stock bearings an-all.
Looking at the pics, it's unlikely there will be a problem with the frame 'they're very strong and can take quite a hefty head-on'. Jills bike was quite a mess when we got it. Very bent at the front. Anything your not sure of, just walk away.
As I said PM me if you have any questions.
Thanks Val (all)
The forks are not through top yoke, and I can see no sign of a linkage (Kouba etc).
I can sit with feet flat and knees well bent, Bev all 5Ft 1"
can get her toes 'flat' on ground.
From this I guess it's a factory lowered model. Pics if any assistance.
