Lumpy idle after TC cam chain tensioner replacement
SimonD
London
I've just replaced the cam chain tensioner on my 43k mile 2010 TC and am struggling with a rough idle.
My immediate thought was an unseated cable but it all looks ok to me.
I used a Motorworks replacement tensioner which seem to put an awful lot more pressure on the chain than the oe one. I've seen posts on-line suggesting that this can cause cam timing issues but it seems unlikely to me.
I'll probably re-install the original and see if the problem goes away but does anyone have any experience of this?
check the valve timing - should have double checked that before start up ?
I've checked the cable seating. I'm not sure I understand how valve timing can be affected by a tensioner change.
Start by asking yourself some questions
1 ) Why did you change the current tensioner ?
2) do you know what a cam chain is / how it works ?
if the answer is / was it was rattling, may draw you to the conclusion that the current chain or tensioner was very worn ?
The chain keeps the timing of the valves set to open / close at the correct time the pistons come to the compression period at the top of the bore
Move it one tooth, you may get a stumble or misfire, at worst its a bent valve or holed piston
1. It was rattling
2. Yes, I have rebuilt several car/motorcycle engines in the past
It still doesn't explain why a cam chain would jump a tooth while unbolting an old cam chain tensioner and bolting in a new one without turning the engine.
1. It was rattling
If you didn't ensure that there were no valves open (e.g. TDC compression), the valve springs can move the camshaft.
1. It was rattling
Its a tensioner , it keeps the chain under tension to prevent it jumping / slipping teeth
If its stretched that far, and you take the tension off, you may have pushed / pulled the chain over a tooth when you replaced it, or as you said it was very tight to fit,
Have you put the old one back and has the lumpy idle gone away ?
Happy to accept i'm wrong , some of the resident experts may offer anothther diagnosis ,
OK, thanks for that I see what you mean now.
I was also concerned about the cables inside the box.
Anyway, I pushed and pulled all the cables and reseated the plugs before trying it this morning - the idle was still lumpy.
Popped down to the garage when I got home this evening and it started up as smooth as ever!
Will finish the service over the weekend and give it a decent run.
Thanks all.
Looks like it might have been the Bowden box. Mine has done almost exactly the same. Just from tank on/off several times.
Hopefully you can get it there and enjoy it now ☺️
