Main Beam Adjustment
Jimb
Guys, Does anyone know if the main beam is adjustable ??
Iv'e adjusted the Dip beam OK and have the lever in the solo ( horizontal ) position and thats fine now but i'd like the main a little higher and can't for the life of me work out how to adjust it, if indeed its adjustable.
Thanks in advance.
Front Cover.
Never had to do it Jim, however while messing with the electrics I had to remove the silver console cover as well as the light surrounds. I think you will find the adjusters behind the light surround. :confused: I did say I think !!!
Thanks Gazza, I'll give it a go, the book is not very clear on this point, i'll let you know how I get on.
Gazza
Gazza, sorted mate thanks very much, there are two screws to adjust the headlight, I figured out which did the elevation and its spot on now.
