doctorsmudge
Right, bare with me. I usually do all my map planning on my 2650 unit. However, I'm off to France in a few days and I as the routes are quite complex I thought it would be easier to use the mapsource for the planning. However, using Metro Guide V9, or European City Navigation V5 when I put in a route and it draws it up on the screen, it seems to straight line over some parts, gives the route as the crow flies between some points, follows the route on others. Also when I download the maps onto the 2650 it states that the route does not match the available maps? I'm given the option to recalculate it or use it anyway, again with it straightlining parts of the route on the unit. I've loaded the same maps onto the unit as I'm using on the PC for mapsource so why is it straightlining parts of the route on the PC?
Any help much appreciated
, got the download, I only had to recalculate the old routes instead of doing them all again and it corrected itself. A real life saver. Metro Guide has more detail than City Navigator V9 I think. Cant thank you enough.
