Duncan
Yo dude, I saw from your avatar that you have fitted some hi level lights, Iwas thinking of doing similar. Any chance of a close up piccie??
Duncan said:P.S. Do you run them with High beam, low beam or independantly?
Mike O said:I've actually changed my lights since that pic was taken, but still have 4 extra lights. They are configured as follows:
Dip beam - 2x fog lights (the lower ones) + normal dipped headlight
Main Beam - 2x spot lights (the upper ones) + normal main beam
I also have the fog lights independently switched (via an Autoswitch) so that I can revert to normal dipped beam in case I get pulled by a particularly pedantic John Q Law (which hasn't happened yet). Gazza sent me a wiring diagram showing how to achieve this set up (I really didn't want to be riding with 6 lights on) and I can post it if you need it.
MikeO![]()
