Metal mule exhaust
  • Thread starter Thread starter ericthebrave
ericthebrave
I was going to tag this on the end of the metal mule exhaust thread a few posts down, but its a closed thread now!
Anyway....what does the metal mule exhaust sound like? much better than the original?? And is it a lot lighter than the stock can? Any power increase (i mean noticeable....i think it says on MM website it removes the flat spot midrange)
Thanks in advance
I can't say on the 1200 but on the 1150 I can tell you that:
1) It sounds much better than the original, but not as noisy as a Remus
2) It's a lot lighter than the stock can (but then so is an anvil!)
3) Power increase - it's hard to say, I do tend to ride it harder but I think that's a combination of factors.
I like mine a lot, as I say that's all for the 1150
Had one fitted before collecting my bike.
1) It has a deeper tone but is not noisy, have been told it does sound
better than standard.
2) Yes.
3) Fitted before I used the bike so can't comment on flat spot.
Posted pic's on http://www.ukgser.com/forums/showthread.php?t=72327
but responce was pic's don't appear let me know if you can see them
please.
ride survey
I have the MM scorpion silencer on my 1200 as part of the pannier set up.
According to the ride test a couple of months back the Scorpion can outperforms everything else..........................
The sound is much improved, and weight reduced. If I am doing long motorway runs (which I hate) I replace the removable baffle to quieten the bike down. Otherwise I run with the baflle out.............it sounds superb (so everyone tells me) and has lovely popping on the over run.
For me the whole set up is a 'look no further'................... have now done about 4k miles with this set up. :beer:
flat spot
Overall the bike seems to have more grunt with the baffle removed, but you pay with extra fuel condumption. I have not been aware of any flat spot.........the bike pulls like a train !! :D
As long as it's easier to mount than the MM pannier frames :banghead: :banghead: :banghead:
Quicker !!
Absolutely the MM pannier frames and rear rack took 10 minutes to fit, the silencer took 11 minutes :D
It did take 12 min's and 15 secs to fit the pannier frames and rear rack to the G/S.......................... of course it should take less than a minute I suppose :thumb
