Metzler tourance
Marlou
Berkshire
Is anybody able to advise me of the correct tyre pressures for my 1150GSA, it has tourance's fitted and I have tried the search facility but found nothing and the Internet search gives conflicting pressures!!!
I have been using front 36psi and rear 39psi but have been told the rear should also be 36psi. Someone else said rear 42psi:blast
I am normally running 1 up with no luggage, I assume that if loaded or 2 up or both it should be F 36psi and R 42psi??
Any help would greatly received:thumb
36 front and 39 rear. (42 rear with passenger and luggage) :thumb2
Thanks for the replies that's pretty much what I found on the net, I've run 36/42 but the guy at the mot centre blamed my worn rear tyre on over inflation and I just wanted to make sure I don't do it again.:blast
Think I will try 36/39 for a while:D
Cheers all
:augie
