Madmountainman
Today, mostly in the interests of research, i gave my panniers a good wash down, so they look good for the BMF! Well, i gave the front lower mounting bolt a good pressure soaking and....
my panniers leaked!
It looks like the water is ingressing on the pannier via capillary action.
Solution???
Simple!!!
I got two pieces of old cycle inner tube (motorcycle tubes may be too thick), cut them into square-ish shapes, cut a small hole in the middle and placed them over the bolt, between the pannier itself and the mounting bracket (make sure you do it up good 'n' tight).
I then gave it double the soaking i had done previously.
Result???
Dry panniers!!!
Hope you find this useful Mike and that it works for you too. Anyone else with Vern's panniers, feel free to do likewise if you encounter the same problem.
Cheers one and all!
my panniers leaked!
Solution???
Simple!!!
Result???
Dry panniers!!!
Cheers one and all!
