Misted headlight
bone
The inside of my headlight keeps misting up, has anybody else had this?
Check seals and use a smear of silicon if needed. My GSA aux lights mist over on a warm day after a wash. My mate uses jetwash and his filled up - you could see the water level move after he took it off the stand. Water = corrosion - corrosion in electrics is not good. I took mine apart lubed up the seals and a smear of silicon and hey presto a fix.:clap
