Hi guys,
looking for a bit of non-GS (but BMW!) help/advice.
Just had my Dads' 1998 R850R for its MOT. Same garage as last year, but a different tester.
He grumbled about the 'front end being a bit stiff' and failed it for 'inadequate damping on front suspension'. I couldn't really argue the point about this. My Dad doesen't use the bike much and the front shock may have seized since the last test. No signs of leakage etc. Anyway, we replaced the front shock and resubmitted the bike for retest.
Tester grumbled again about 'front end stiffness' (stop giggling at the back
), but reluctantly passed it. He roadtested the bike and said that it felt 'no different to before'. Then said that he could 'hardly turn the bars'. We then realised that he was talking about the steering damper, not the front suspension. He demonstrated that if the bars were turned sharply, then they became stiff, but had a smooth, full lock-to-lock movement range if operated slowly.
Questions:
Is the tester a clueless moron, who doesn't know the difference between suspension damper and steering damper?
If the bike was no different to previously, why did he pass it? Shouldn't he have failed it again?
Surely, this is the way a steering damper is supposed to operate - reacting to sudden jerks but allowing smooth movements?
Next year, should we take the steering damper off for the MOT, then replace it afterwards?
Anyway, lesson learned, I'll try a different garage next year
), but reluctantly passed it. He roadtested the bike and said that it felt 'no different to before'. Then said that he could 'hardly turn the bars'. We then realised that he was talking about the steering damper, not the front suspension. He demonstrated that if the bars were turned sharply, then they became stiff, but had a smooth, full lock-to-lock movement range if operated slowly.Questions:
