MOTECH Bar fitting
Not open for further replies.
Lofty
Fareham, Hants
Anyone live near the Fareham area with a full set of Motech bars fitted?; I've put mine on and have a bolt left over each side - I'm worried !! Should I be ? - pls excuse my ignorance in advance ...
Two big ones with spacers in the engine mounts
Two M6 bolts high up with spacers and rubber grommets
Two M8 nuts and bolts in each end of the upper cross brace
Two M8 nuts and bolts in each end of the lower cross brace
Two bolts/spacers in the lower cross brace up into engine through the sump guard
On the nearside upper M6 bolt area, check that the crash bar bracket does not foul the pipe. You may need to relieve the bracket with a file (or a gentle adjustment with an angle grinder)
This relates to the lower bar set only (R1200GS)
MOTECH Bars
Thanks,
The bolts I'm looking at and not seeing the obvious answer are the upper M6 ones, I'll go and take a closer look when I've finished the school run ....
