Motobins brake pistons - plastic face covers?
MMC
Probably in the office. Again.
May I have your advice chaps?
I'm rebuilding my calipers on the Panzer with s/s hoses, plus new pistons and seals. Just got the new pistons from Motobins. Unlike the old pistons, the new ones come with a sort of holed plastic cover on the pad side that sits slightly proud of the piston edge:
Not seen this before... The old ones have no cover (hollow cups) and ones I've used previously have been likewise. Are these plastic covers just a bit of protection that needs levering out before fitting or do I leave them in place?
I'll give 'Bins a call in the morning but wondered if anyone else had got the answer already.
And yes, I realise it's a klutz question :D
When I did my 2000 1150 brakes they had the plastic covers in place on the pistons.
I'm going to go controversial here and suggest the plastic caps should be taken off before installation..... for the simple reason plastic will compress under the forces imposed during braking.
:rob
Oooh - 50:50 now!
Any more votes? Or shall I just leave the brakes off altogether? I never really go fast enough to worry.
Oooh - 50:50 now!
I would suggest plastic should not form any functioning part of a brake piston.
I don't know this to be true, but I feel it.
Its standard that they are fitted
Its the anti squeal mechanism that BMW chose to utilise
Ah - cool. I'll give Motobins a call this morning too, just to make sure :D
In the meantime I'm on the hunt for a set of rear caliper pistons. The Motobins kit for the fronts includes pistons. The kit for the rear just seals. Go figure.
It works too because my front brakes squeal now because I managed to crack the plastic covers.
Yes, it's only after the event you realise that levering them back with a screwdrivers' not a good idea :D
Ha, my bike has the plastic covers on one calliper and none on the other :nenau
... so it only squeals on one side :blast
You should leave the old pads in and lever against the friction material to push the pistons back, they re scrap anyway.
John
It was a bit more than that as the pistons needed cleaning to get them back in place, hence I had to remove the pads. Took us an hour or so to get em back in and had to do each piston individually. I will be rebuilding them over winter with new pistons.
Guys, buy the correct tool or use a "G" clamp, make blocks of wood to hold the replaced pistons fully home as you press in the next ones.
It's a 10 minute job per caliper :toungincheek
