hi all ,
does the motronics loose it,s memory if the battery is flat?
because my bike will not run past 3k rpm after fitting a remus and Y piece, before this the bike was last started october and of coarse the battery will not last that long without going flat , i have checked everything there is to check i even put the standard exhaust back on to satisfy myself i have put new plugs in and a fresh fuel filter , made sure all pipes are where they should be , checked cables , relays , all electrical connections but nothing . help cheers andy.
