mounting a Garmin Quest on a HP2
Jeremy
Devon
Anyone have a suggestion as to the optimal place? do I use the standard RAM U-bolt mount and a Quest cradle and bolt it onto the handlebars?
GPS Mount
I've fitted a Streetpilot 2610 using the standard BMW mount for the HP2. I'm not sure but I would assume the fixing bolts of the Garmin cradles would be a standard type across the range?
Cheers, Rick
The Garmin cradle fits straight onto the BMW mounting plate (which is a bit expensive BTW) as you can see in the attached photo.
Jeremy,
Few weeks back I managed to get a look at Tallgirl's HP2 and (if memory is working :eek) settled on a u-bolt setup. I did look around for 'nooks and crannies', but do not recall any of the 1" ball on post or thread jobbies were an option, the rail for the screen and clock was a possible.
Spotted this on an HP2 in France recently - not sure which GPS it is for but it may help what you are looking for.
