Mounting HELLA Micro DE on BMW R1150GS (PDF)
  • Thread starter Thread starter eugnas
Nice report, pity its all in a foreign language. :rolleyes:
But forgive me in asking, but have I not seen some of those photos somewhere else. :nono
In fact I'm sure that I have, unless of course you have fitted a Autoswitch to the same bike in my garage without me noticing........ :confused:
BTBR
Yes It's true. I've used one picture of fuse box, but I don't remember where I've found it. If that picture is Your, I apoligize. And If you want, I write the picture is your.
Your work was great!
Massimo
Massimo
No worries, its nice to see that "BTBR Inc" is going world wide... :clap
BTBR
Ciao Massimo,
Well that is very similar to my R1150 GS Driving Light Relay and AutoSwitch Install, except I took it a few steps further. As you'll notice, I tapped my cancel wire into the turn signal relay. Also, not a single BMW factory wire was cut or spliced into.
It looks like you put your Driving Light Relay & AutoSwitch in the same location. And you also tapped into fuse no. 8 as I did. Hmmmm, where did you get all those ideas from? ;)
Your "Fusibili Supplementari" is nice and compact and I like the thought of it being within the main BMW fuse box. This is my R1150 GS Blue Sea 5025 Fuse Block Install.
By the way, if you are mounting a GPS using a RAM Ball and don't know where to put one, here is my elegant and simple solution that does away with unnecessary brackets.
See you on Monte Baldo in June... :beerjug: :thumb
