Well what can I say! Spend most of Saturday cleaning and redoing the carbs. Got gringo started with a severe miss and splutter. Decided to get the bike home at least and rode on one cylinder back to Stratford from Norbury thinking of all the possible reasons why the bike is suffering from fuel starvation after I have fiddled with the carbs. Coming into blackwall tunnel pulled the clutch to gear down for slow moving traffic when I realised there is no clutch. Mmmmm not good and blood pressure slowly rising to new stress level. Managed too not stop untill I got home still battering along on one cylinder. At home checked the clutch adjuster which by now is set all the way in and can't be set anymore. Park bike and go to sleep seems good option.
Sunday morning up and first thing checked the carbs and my suspicion that the float levels were set to much was right. Bend the one carb float level a bit and viola no problemo starts and idles like it did before. Now the clutch seems to not engage at all so read the book and seems there can be only two problems, one the clutch plate has worn down and the end of it's life after 60000 miles has been reached or the fault could range from worn clutch mechanism piston to a bend pushrod???
Have any body have problems with the clutch just leaving the building without saying goodbye?
It never slipped or had weird symptoms as you would usually get with a clutch. The one moment it was there the next moment it was gone? The book does refer to the piston getting stuck when worn oval and several small possibilities but before I strip the gearbox out again I would like to look at more simple solutions or options.
Finally my battery was also fully tickle charged and seems to be happy again. I reckon gringo is tendering for a new owner.....
Any thoughts?
Any thoughts?
