swissrob
hi,
I been having a look at finally fitting the tool tube but ran into a prob....
the tube fits fine on the RH side in the same sort of area as the vario pannier bracket BUT there is little clearance between the tube and the wheel - if going over some dips/bumps then i can see the tyre hitting the tube.
Where have you mounted your tube?????? photos would be appreciated
