MRA Screen on 1100
Yes and Yes.....well actually I have the Wunderlich vario which is a rebadged MRA Vario. I had a Givi before and I find the Vario gives better airflow and no buffetting - you still get lot's of wind noise - if you are looking to cure that best buy yourself an RT instead of the GS.
I have mine set to tilt right back and on the highest setting . I am 6'3" and the suspension is set high and I have a non stock saddle which is on the highest position and is 4cm higher than a B£W standard seat .
I am 6'3" and the suspension is set high and I have a non stock saddle which is on the highest position and is 4cm higher than a B£W standard seat . [/B]
Christ they must have high bridges round your way!
Thanks Gecko, I will look into getting one.
Mike.
Mike
I have an MRA screen on my 1100. Excellent job. A bit noisy but I wear earplugs so thats not an issue. No buffeting either. I'm 6'1" and have no problems with it.
It looks well too (but then all 1100s look good :D )
Recommended.
Ferg
me too...
yup, I've got one too. Black tinted. I'm 6' 2". Mine is set high as poss and as far forward as poss. Significantly less buffeting and noise than standard screen. Seems a bit flimsy when you first fit it, but it's stood up to 18months use and abuse without problems.
I've also got Saeg Ta edging on the upper bit. Makes it look a bit cr*p, but makes the screen think it's 4" bigger. This combo gives a nice little air pocket of still (ish) air to sit in.
