Mudsling mod to fit with Motech panier rails
bikemad
Ramsgate kent
Brought a mudsling was S/H so didnt mind cutting it a bit had to mod both panier rail fixings too easily enough.
Started by lining bits up to cut the slot out of the sling both sides then modded the fixings had to countersink the upper holes cos bolts come tight to them I swapped them round left to right see pics all works ok not sure if tyre rubs at top of travel but all looks good so far resprayed the brackets cos paint peeled off lol.
heres the last few pics fitted I drilled one new hole for cable tie on the right side cos Id cut into that area otherwise fairly straightforward.
