I`ve fitted new HEL braided brakelines to my Kalahari 1100.
I`ve bled the system...from master cylinder to ABS,from ABS to calipers.
I`ve re-bled the system...and bled it again.
Sometimes the feel at the lever is fine...firm,almost heavy to squeeze but smooth and feeling constant when squeezed.
Sometimes the first squeeze produces a spongey feeling with low resistance until a second squeeze restores it.
When I got the wreckage of the bike from the Insurers the front brake was very spongy,and I saw that the master cylinder was almost empty.
I discovered that the banjo bolt was loose on the right hand caliper.
I`m now not too sure if I`ve got air trapped in the master cylinder piston seals....or if the seals are worn and need replacing.
I`ve changed master cylinder piston seals on my R80G/S,but haven`t touched the brakes on an 1100 before.
Any advice or comments ?
